Cutting a logo in 3D (or otherwise)
Given a project which has a rather rough 3D model:
We work up a nicer version by first sourcing a vector version of the logo:
https://seeklogo.com/vector-logo/281429/green-bay-packers
Since it is an EPS, we open in Inkscape or some other vector editor which is able to parse .eps files:
and export as an SVG to import into the file and recreate.
Draw in a second rectangle:
and then use the outermost to model the stock:
Apply
Select the interior elements:
and subtractively model them:
Apply
Show 3D:
We then try applying a 3D toolpath…
and a 3D Finishing toolpath:
OK
which doesn’t quite work since the 1/8" tool is too small to fit in the details:
To verify this, go back to the Design pane and draw a circle:
So instead, we try an Advanced V carving:
which previews as:
attached as a v8 file:
green_bay_packers_logo_v8.c2d (164 KB)
Love the solution. Would like it even more if it had “Steelers”.
That was done/shown in “The Gallery” a while back:
Seriously though, if you have difficulty with any logo, let us know and we’ll walk through it with you (or find a previous occasion of having done so). Further note that you are on your own in terms of licensing.
