All examples of cutting arcs seem to be in the X Y Plane
If anyone know how to cut an arc in the Y Z plane please let me know.
Goal: to cut two 1/4 slots in the back of a guitar neck for strength.
The guitar neck is aligned in the Y direction with frets facing down on machine
The guitar neck changes angle to 17 degrees and rises up in the Z plane (tuning pegs mounted here)
I am trying to cut an arc in the Y Z plane that is 4 inches long
The height of the Arc is .0955 inches
Using the calculator, I get a 20.99016 inch radius at 11 degrees
The code below is for linear motion - it is close to what I need
but as you can see it is not a curve
G90 ;absolute positioning
G20 ;inches
G0X1.0Y1.00Z0.070 ;move to starting point
G1Z-0.05F8.0;lower the bit down from zero for first pass
Y1.50; start here
Y3.50F8.0; move from starting POINT 2 INCHES at a feed rate of 8
Y5.50Z1.00F8.0; START CLIMB UP THE NECK
any help would be appreciated to know how to program an arc instead of linear motion
