Cutting an arc in the Y/Z Plane
All examples of cutting arcs seem to be in the X Y Plane
If anyone know how to cut an arc in the Y Z plane please let me know.
Goal: to cut two 1/4 slots in the back of a guitar neck for strength.
The guitar neck is aligned in the Y direction with frets facing down on machine
The guitar neck changes angle to 17 degrees and rises up in the Z plane (tuning pegs mounted here)
I am trying to cut an arc in the Y Z plane that is 4 inches long
The height of the Arc is .0955 inches
Using the calculator, I get a 20.99016 inch radius at 11 degrees
The code below is for linear motion - it is close to what I need
but as you can see it is not a curve
G90 ;absolute positioning
G20 ;inches
G0X1.0Y1.00Z0.070 ;move to starting point
G1Z-0.05F8.0;lower the bit down from zero for first pass
Y1.50; start here
Y3.50F8.0; move from starting POINT 2 INCHES at a feed rate of 8
Y5.50Z1.00F8.0; START CLIMB UP THE NECK
any help would be appreciated to know how to program an arc instead of linear motion
In theory one could program G2/G3 arcs to do this by hand — in practice, it’s tedious beyond reason since Grbl doesn’t support loops and variables.
There are a number of programmatic tools:
https://wiki.shapeoko.com/index.php/Programming
I tried to do this sort of thing using OpenSCAD and was scolded for creating objects with untold numbers of triangles which brought the program to a standstill.
A bit more workable option would be to model the neck in Carbide Create’s Pro 3D modeling mode which is currently free for 1 yr.:
Or, use a more conventional 3D CAD and CAM toolstack: https://wiki.shapeoko.com/index.php/Online_resources#Guitars
the other thing one can do is use my (somewhat new) tool where you can “fold” any Cabide Create generated GCODE over a surface as specified by an STL tile… (but it does not support g2/g3 arcs yet… I need examples to test for that)
see Test cuts with the newly installed spindle
