What does that mean? Why does the depth of the workpiece matter?
Thanks for continuing to develop this!
STL files don’t really have a dimension, so I use the depth of the wood to scale the STL vertically to fit that (for horizontal I then keep the same aspect ratio)
I finally had time to read this paper, and it’s quite interesting indeed. I’ll now wait for @fenrus to implement chip thickness control in toolpath generation in his ongoing (and impressive) CAM endeavour !
All that effort for inside out (vs. outside in) pocketing!
made a new release just now, performance is much more reasonable in this release. The previous release (with the reduced stepover) would take 1 1/2 minutes to compute the geo stl file, the new release does this in 8 seconds.
An interesting alternative approach - using cutting power feedback to dynamically adjust feed rate. As explained here, cutting force is proportional to machine force (which is typically what limits CNC router performance).
Since actual feedback is … complicated, I was planning to make some sort of model and use that to control feed rate. Assuming the model is close enough to reality that should work
(fwiw I still am trying to get my head around how on earth I’m going to do that… but once I do I get rest machining for free as well)
What part is complicated?
So the idea I have is to keep track of what is cut already and what not, and then for a path, calculate the intersection to see what the cut mount/cutter engagement is.
The complicated part is the keeping track part and to do that in an efficient way. Option 1 is to do basically what camotics does, option 2 is to “subtract” all previous cut paths from the forward path. I haven’t figured out which one is going to work
(and first I want to wrap up the STL cut feature)
Sorry - I was asking what’s complicated about the dynamic feedback approach.
it means the gcode sender needs to get involved basically
also… any force measurement is backwards looking with, at best, a small delay… how much the past is a predictor for the future is a curious question and depends a lot on the geometry
That’s what control systems do.
weekend update; decided to spend some time fixing bugs and add a CI capability.
So now I have a tool that takes a gcode file, and turns it into a “fingerprint” which has basic info (like dimensions) and samples the remaining material height at regular intervals (currently 1mm)… and can then later compare a new gcode file against the fingerprint to verify nothing really changed…
… and I added a set of test files in a 2nd github repo with makefiles setup so that I can quickly rerun these files, and then use the fingerprint tool to verify nothing bad happened in the code of the tool
Finally implemented adaptivedynamic F&S for pocketing toolpaths.
It’s not the Fusion style “do half arcs” but much simpler, calculate for the next bit of the toolpath what the actual engagement will be and scale the feedrate to the inverse of that (clipping to [0.5 , 1.2]) while assuming that the feedrate in the CSV from CC was set for a model of 50% engagement.
Engagement is a 3D property so “half of stepover” and “half of depth” are assumed equivalent.
For a “normal” inside out pocketing, when approaching a corner, the feed rate goes like this
100%
100%
83%
63%
52%
– corner
100%
while the “outside in” approach starts with a full perimeter pocketing at 50%, but then goes to a mode of either 100% or even 120% (for the corners)… assuming a nice square.
ok playing with various models from thingiverse… it seems that the limit for toolpath currently is roughly 3.2m vertices… (e.g. a 162Mb STL file)… does anyone know how that compares to other tools (fusion360/etc)… is this close enough or do I need to spend some time doing more performance optimizations
I think (and have experienced) that it takes much less than that to take Fusion360 to its knees, on my PC that is.
Spare yourself the trouble of further optimizations, that will give you more time to work on adaptive toolpaths
ok so the adaptive feedrate works quite well… it does all the things I expected it to do. I’ll attach 2 gcode files for reference that have this enabled.
It also is actually a lot less code and complexity than I expected… it really operates at the layer where gcode is being written out… makes me wonder how the new Carbide Create post processors work, since I suspect if those are an API kind of sorts this could be implemented in maybe 200 to 300 lines of C++ code in the post processor…
Simple square pocketing: square.nc (48.7 KB)
Complicated test shape pocketing: testpattern.nc (506.7 KB)
this gcode was done in verbose mode where for each gcode segment, it contains a comment for the estimated cutter engagement for that segment as well as the speed selected because of that
