Has anyone cut holes in sheet metal? If so what bits, feeds, speeds, etc.
If possible I would like to cut some holes in electrical panel doors and back plates. The panels are .059" carbon steel. Most of the holes would be 22mm in diameter with random 2" holes. The back plates would have a bunch of small holes (“0.159” diameter) for mounting equipment. This would make my life a lot easier if possible.
If not I may just use the router to engrave some indents in the sheet metal so I can drill them out later.
