How would one go about cutting a trough, let’s say 1 inch wide, that has a variable depth? One end is .25" deep, and it flows downhill to the other side, to a final depth of .5"? Or am I gonna need an angled shim and a bowl bit?
We worked up a way to do this using BlockSCAD here:
If you’ll provide the dimensions (length?) we can create a file for what you want to do.
This is fantastic, Thank you.
