I currently am using Carbide Motion so I’d imagine I’d either need to write some probing macros and run them manually or try different software. Can anyone point me in a direction here? I have no interest in 3D scanning. Just hoping to do things like find center of a workpiece, or probe bores.
I’ve used the V2 probing routine with conductive materials to find bores, however it errors out after not long so probing large bores isn’t possible.
I think I understand what you are saying about adjusting the offset but could you elaborate? You are accounting for the size of the tip vs. where it triggers?
I found this exact probe on eBay and was interested in it - is it difficult to tune the concentricity of it?
Yes I use CM and V1 xy probing routine set with 3mm endmill(same as my probe tip) and then I adjust 7mm witch is the distance from the edge to the recess of the carbide probe. Z I do manual so far. And what I noticed is that it’s as accurate as the touchprobe.
To do more custom probing I will use cncjs and macros for probing. But not there yet.
