There is vertical travel in the Shaft/Collet when applying +Z pressure upwards while holding the collet nut.
Video: https://www.dropbox.com/s/fqik6oz119u9uzd/IMG_3592.MOV?dl=0
If I had to guess I’d say your bearings/router is toast.
Dan
I have a DeWalt 611 on my XXL. Absolutely does not do this.
The router has less than 10hours of run time on it. And it doesn’t effect cuts as it takes a decent amount of pressure to cause the upward movement…
Please contact us about this at support@carbide3d.com and we’ll investigate this with you.
My suspicion is the bearings aren’t fully in place, but that’s just a guess.
As a follow-up this wasn’t normal and Carbide support sent over a new CCR while I was on vacation that does not travel +Z when messing with the collet nut…
