I have to put some 5mm holes in a 6061 workpiece that’s about 12mm thick. I’ve programmed this to bore with a 1/8" two flute cutter, which works. But it’s slow.
I also needed to bore some 2.8mm holes with a 1/16" cutter, which was slow AND dicey, because they need to go 4-5mm deep.
Are these circumstances that would call for drilling rather than boring? If so, is there a drill chuck available for the Nomad3 to support various sized drill bits? Recommendations?
Yeah - that was my worry also. I can obviously slow the spindle down, but then there’s the question of torque. I thought maybe peck drilling, so the spindle could get back up to speed between hits, but that might be an overall slower process than boring.
