Duplicate layers with linear or vertical array
When duplicating geometry with the array feature, it would be nice if it would put the duplicated geometry in the layer it was copied from.
The work-around for this is to set the layer the object is on to be Active, then the duplicated elements will appear on that layer.
…and if the source geometry comes from different layers, you have to do the array operation layer by layer.
I’m well aware of ll the work arounds, it’s just a pain.
