Saw yet another thread about “How do I re-zero my tools in a multi-tool cut”.
Carbide Motion should warn the user if the BitSetter is disabled, AND a file with more than one tool used is loaded.
Your suggestion is a good one. I started on the Shapeoko before the BitSetter was available. In the olden days you would make multiple tool paths and disable all but the first one. Then run that one. Then open CC and disable the first tool path and then enable the second, third …
If someone does not have a BitSetter they could still do that. Since the Shapeoko remembers the X Y only the Z have to reset the for each new tool. Frankly I dont miss the good old days of having to set everything manually. C3D has come a long way from their KickStarter and the first SO3 machines.
