I’m using CC to create a simple V carved label out of a 1/8" laminate.
The first label worked fine. But when I edited the text and saved it under a different name The feed rate changed.
I’ll upload a PDF of the CC screen caps and a scrap of the G code for each file. Note that the second g code has the feed rate to 10 mm/min.
I know I can fix this with a find/replace, but I would like to understand why it happened…
Any ideas?
CM 300 and 211 screen caps.pdf (262.3 KB)
