I have an SVG file that I can not get to load into CC. I have tried to use the “import external file” button under imports and I have also gone to “File” “open” and tried to import. The file in question is not grayed out. When I try to import the file it clicks me back over to the template but the file is not there. I have backed the view way out to make sure that it didn’t place it off of the grid.
Any help would be appreciated.
As noted in the support response, Carbide Create will only import SVG files with vector elements — a pixel image in an SVG wrapper will not be imported, because there are no vector elements to import.
Jeff, I’ve had this issue a couple times and what I do is open the svg using Inkscape, and then save as “Plain SVG”. This seems to clear out all the extra stuff that Will mentioned.
Jeff
