First Sign Attempt
Here is the finished sign. A huge thank you to @WillAdams for your help w the logo. I learned so much on this project. Looking forward to more sign work.
I used single flute O Flute bits for this work (1/8 and 1/4”).
All of the colored parts sit in pockets and are held in place w M5x14 stainless steel screws made for plastic. The base material is 1/2” thick white/black/white Color Core HDPE. The color pieces are 1/4” HDPE.
Great job, turned out really nice!
Sign looks great. Would have been nice if there was a good way to avoid the screws but not much sticks to HDPE.
I use some 3M double sided adhesive to stuck multiple layers of acrylic together. Usually that is work I do on the laser. Put the adhesive on the back of one piece and then laser it so that it is precisely located and fully on the material.
I don’t know if that would stick to HDPE but I can try it. I have no idea if it would hold up well outside though.
That came out very nicely. Great work.
Would some version of gorilla glue or exterior CA glue work?
Hi @Jmcwoodworking
From my research no. This sign lives outside in Michigan where the temp swings will be big. I did not trust a non mechanical joint.
Will
Thank you @Redlander
Thank you @CullenS. Because this sign will live outside in Michigan I felt I needed. Mechanical joint.
Will
Understand and don’t blame you.
Colors and everything looks very clean. Much, much better than my first attempts. Great work!
no. I used 2-component poly resin, was just good to keep the pieces together, would not trust it for mechanically challenging seams. AFAIK there is no glue for PTFE that works like solvent cements for acrylic (WeldOn 3 or 4) on acrylic .
Gorgeous sign! I would be proud to say I had made it. First attempt??!! Incredible for ANY attempt.
On the screw showing side of things. I wonder if the recessed pieces could be thicker and the pockets deeper so that they could be screwed on from the back side… unless of course if this is a double sided sign. And then that idea is just idiotic.
Thank you kindly! Here are a few more pics of how I fastened the parts together. This is my practice assembly. The colored pieces were all fastened from the back. From a distance you can’t see the through holes at all.
Holes in the colored pieces = 4mm, clearance holes in the base layer = 5mm. Would have made them slots if I had a way to chamfer them cleanly.
