dvandhi
(Dan Van De Hey)
February 23, 2024, 2:29pm
1
New guy here, so sorry if a silly question.
Got my machine up and running. Works great, put a couple projects out.
I needed to flatten a oversize cutting board. I ran the program, (pocket cut, McFlY) saw I needed to take more off after 1st and 2nd cuts so I -
1- rapid jogged to x-y zero and made sure I was still good
2 - remeasured and reset z- zero
Ran program- machine went to bit setter as expected, checked bit, went to the correct location of cut start and buried the bit into the board.
Any ideas what step I messed up, and is this an acceptable way to slowly add depth to a surfacing finish?
Thanks in advance.
WillAdams
(William Adams (Carbide 3D))
February 23, 2024, 8:25pm
2
Post your .c2d file?
I went over this sort of thing at:
Given a rough piece of stock:
[20240204_151557]
one sets it on the machine, and if need be, adds shims where/as needed to make it as level as possible. and clamp in such a way that the entire top may be surfaced off
[20240204_155540]
set zero, then begin cutting:
[20240204_171001]
After running the file once:
pocket_464x116_1mm_LOWERLEFT_TOP.c2d (44 KB)
if a repeat is necessary, jog down to zero, then down by the cut depth of the file (1mm) set zero there and repeat — the zero may be …
gdon_2003
(Guy Donham)
February 24, 2024, 12:32am
3
When I flatten my spoilboard I take off 0.010" per pass and pocket only 0.010". If I need to make a second pass I jog off the material and lower the
Z 0.010" below the zero position. I just rerun the file. Trying to set zero with a bitzero can be trying so I just manually jog down and reset the Z zero. I run that as many times as I need to get the spoilboard flat. I make pencil marks all over the spoilboard and when the disappear I am done. On the spoilboard I want to just remove enough for it to be flat.
dvandhi
(Dan Van De Hey)
February 24, 2024, 5:03am
4
Thank you all for the help!
I restarted today, followed your recommendations and it worked great. No more “center boring”…lol
system
(system)
Closed
March 25, 2024, 5:04am
5
