I know…lots of messages on this, but… I have tried everything that has been suggested but the font does not show up in CC?
I have 6 other Windows programs in which the font shows up, including Mind Map s/w, Open Office, ALL Microsoft Office programs, every program that I use on the computer that uses font choices, except for Carbide Create.
I found, downloaded and installed the font on my iMac and it shows up in CC.
CC doesn’t list fonts alphabetically, so you might need to hunt around for it, but all my installed fonts - i.e. the one’s I’ve added myself - are at the top of the list.
I haven’t tried it on Windows, yet…
UPDATE: OK, so I tried in in Windows and I get the same as you - it’s not showing in the list in CC, but does show in other programs.
FWIW - and this won’t help if you don’t have access to a Mac - designing the project in a Mac using that font and then saving the toolpath will cut it correctly.
Most apps usually access fonts using an API call, which is why most apps are seeing the fonts. Issues about OTF and TTF fonts is not really pertinent. If you can install the font, the font is installed and available. If you can’t install it, you can’t install it.
The issue I think is that the cross-platform library used to build CC might be old or at least it only takes into account fonts installed globally. It’s might be doing something like scanning C:\Windows\Fonts instead of using the relevant API call.
Anyhow, fonts you install as your user end up in %AppData%\Local\Microsoft\Windows\Fonts and not in Windows\Fonts.
To install this particular font and use it in CC, right click on it and select “Install for All Users”.
Yep, that worked for me - but it seems to be a bit of a kerfuffle particularly as they are installed for other applications, including VCarve, straight off the bat
