We have notes on this at:
Where does it ask that?
Iāve actually already looked at that. The thing is that it isnāt like that anymore and there is no Carbide3d.cps listed that I can see
See screenshot. When Creating a new setup in Machining workspace, the first page has āSelect Machineā
This is what the Post Process tab now looks like
Blanius: Where you define the post processor is in the āActionsā tab. See the top, 3/4th of way to the right side:
The āSetupā are you showing is only to define the stock, the workpiece orientation, zero location, etc, and has nothing to do with CarbideMotion / GRBL.
AH HA! Found it⦠Itās a little different now:
Video removed
You donāt need to select a Machine. We had a big thread on that somewhere. Iāll dig out a link later.
Post process is in the same spot on the toolbar in the āActionsā panel. I donāt remember it being anywhere else.
Edit: Just as @kelaa stated already.
Ok sorry, I havenāt used Fusion for Machining and I though it used to be on the Setup on the last tab
Hereās the link to last thread about machine definitions.
Might be worth noting that Fusion is likely to change these dialogs and features around again soon as theyāre trialling NC programs as the new way to post CAM
https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-POST-PROCESS-NC-PROGRAM
Iāve been using that preview feature for a few weeks now and I think itās a huge improvement.
Iāve been doing the same.
Curiousā¦Why do you like it better?
Aside from it fixing the target folder bug on OSX, the main aspect I like is that I can group the CAM paths that use the same cutter together into a named NC job which I can then just re-post with the same filename, overwriting the old one by just right clicking on the NC job after messing with toolpaths to fix things.
You can also really easily re-export just a couple of toolpaths, say when sneaking up on a measurement just by unchecking the others in the NC job.
I did confuse myself a bit by deleting and adding toolpaths in my folders under the setups and forgetting to go edit the NC job selections but I know that nowā¦
Iāve also found the stock āfrom preceding setupā to be an excellent addition for multi-sided machining, especially using the simulation to check what youāre cutting and when.
So, what did you like about it?
Are you guys paying for Fusion?
Noooop, not me.
The pay features Iād like are extra on top of the $400 / year such as the 4th axis machining and I donāt sell anything from my machine so I donāt feel guilty about it
This topic was automatically closed after 10 days. New replies are no longer allowed.
