1st off; Just got my XL Z-Plus in and built, but haven’t even plugged her up yet. With no prior experience with cad type programs I’ve been struggling a little with a few concepts but getting a little closer. I’m proficient with Photoshop and have been able to import those to Illustrator, create svg files and then import those to Create Pro. So here is my problem. I’m wanting to create a curved surface from the top of my build to end about 20mm lower than the surface. I’ve attached a screen shot of the body and If you look at the top you’ll see the body curve. Can Create Pro do this kind of cut and if so can anyone give me a little info to nudge me closer. Thanks!!
Extend the area beyond the edge of the guitar as described at:
Thanks William, I’ll check it out.
