Note they have .STEP files there (Fusion 360 can load them), and the pieces all look like stuff that could be done on a (calibrated) 3-axis CNC. Like an S3.
Note they’re quoting ~$15.6k for the machining. Wow.
There’s a video about the project, which puts it in context:
That does look like a really good challenge and I actually have a very simplified version of that in the works. A sports oriented prosthetic ankle/foot for a friend of mine.
One reason the S3s haven’t been running as much is because of the sheer difference in ridgidity seen in the Nomad and even the Bantam.
We are almost ready to move into the new shop and that requires $$$, which sucks because I don’t particularly like to whore out.
New projects coming, maaaaybe not robots but still cool.
No worries. If you’ve any interest in having a chat to the people working on that Open-Source Leg project, they’re friendly. Can put you in contact with them, or you can grab the contact details of their main person direct from the website (it’s in the footer of all their pages).
Interestingly, was chatting about rigidity and vibration characteristics recently with a (very, very knowledgable) CNC builder veteran who used to work for SpaceX (creating CNC machines).
Apparently although rigidity is important, dampening vibrations is also critical. Hmmm, I’ll cut-n-paste what he wrote, as it was the first time it’s been explained in a way that sunk in (for me). Apologies for the wordiness:
He went on to explain:
Epoxy granite was mentioned as a good vibration dampening material for this purpose.
Maybe something to add to the upcoming things-to-try-out list?
To make a bushing out of solid stock I would use the other set of jaws to hold it on the outside well. Then run an adaptive clearing operation then bore to finish the inside.
