Hardcore Aluminum milling on an S3
I have a full quote for three JGL spindles but even the cheapest comes out to $1750. Also there is a big weight difference between these and the other spindles. It would be silly to buy one of those yet still run V wheels imo.
I have three spindles
0.8kw 24krpm 65mm 110v with sk15 ATC
1.5kw 24krpm 80mm 110v
1.2kw 60krpm 62mm 220v
Both 110 spindles use the same VFD and the 60k is just unbelievable. All in all I only have $1500 in these spent over a good amount of time (cnc work paid for them). While combined they come close to the same amount of money, using one would not be good data. Those are far out of the price range with these machines and would upset the balance imo.
If I can get the 60k going like it should, its a far better option for the masses.
@gmack
I’m not a VFD expert and in manual controller mode I cant seem to get it to output more than 1.75amps. When switching to PID plus feedback it will output much much more and is set at a 4.5amp max. However because I need a 10v converter for my input, haven’t wired it into the board yet.
