I am having issues converting a JPEG into a vector file. I’m using Inkscape and the path_trace bitmap wont give me a good enough vector to use in carbide create. Any hints or tips?
Try CC 520’s new image trace function?
Had to adjust the levels and resave as a PNG:
39.c2d (58.4 KB)
Did you try the multiple scan section at the bottom? I’m not home so cant recall exact screen options.
Sometimes edge detection doesn’t work for me so I use the multi scan using 10 or 12 scan and I believe the bottom option. After its scanned right click and select ungroup, which will give you 10 or 12 separate images. I just click and drag 1 so I can see it separately and delete all but 1 which looks the best then save that as .svg.
