How do you set up a Drag Knife
Cutting EVA foam, how do you set up a drag knife so the spindle does not run?
I always just unplug it (and the vacuum) as well as set the spindle speed to 0 or 1 (depending on which Carbide Create version I’m using and what is supported) or, I edit the G-code to not have spindle on commands since I have to hand-edit the G-code for corner arc overcuts (or at least that’s how I did it the last time) — Carbide 3D doing an official drag knife and adding support for it in Carbide Create would do wonders for my getting back into leathercrafting…
I can attest from experience that having the spindle run with the drag knife in it is a very bad idea :joy:
Luckily when I did that I was using the compact router. I needed a new drag knife and also replace the innards on the router.
