Sorta got the xxl up and running. still have to make a threaded wasteboard and wanted to see what the cut accuracy is. I tried out the concentric square and circle idea as mentioned here GRBL $100 & $101 Issue
Only difference is I cut out patterns from 40mm to 190mm in 30mm increments. This first set was with the Grbl settings for x and y at the stock 40 setting.
Thinking I can do better used this data to calculate new values for the Grbl x and y. This is the result:
This seems better in the fact of the squares are more square and circles are less oval. The data is suggesting the bigger the object is then the bigger the deviation from the desired size. Would this suggest I have a setup issue somewhere? Its not by any bad by any means, the fellow who posted his test had more of a consistent deviation from the smallest to largest test cuts.
