As requested on support…
Given a file where one has text, and a support which one would want to be in the background:
it is pretty straight-forward to create two separate pieces of geometry which will cut out the text, and the text with support.
First, we need to restore the original geometry for the support:
Check the size of the selection:
Then we create a duplicate of the text and send it to a hidden layer for later use:
Ok
Select the text and the support:
and use the Trim Vectors command to remove the text which crosses the support:
OK
Delete the original support rectangle:
Select all the open (magenta) geometry and Join Vectors:
arriving at:
Use the Layers palette to show the text:
With two sets of geometry:
one can assign separate toolpaths so as to achieve the desired effect of the text above the support.
For best detail, this should be cut with a V carving — in order to do this we will need offset geometry which defines the width which the V endmill will need to cut in order to cut as deeply as desired. Draw up the tool which will be used in profile:
and draw in the desired depth:
Then measure the width:
and offset the outer geometry with the support to half that distance:
and then offset the tittles on the _i_s which were left out previously:
and union their offsets with the offset geometry:
OK
Select the offset geometry and the original text:
and cut as an Advanced V carving:
which will preview as:
Then cut as a pocket down to the height which one wishes the letters to stand proud. Since the #102 endmill only has 0.5" of cutting flute length we will keep this w/in the capabilities of that tool. Sourcing a longer tool and adjusting the file to cut more deeply is left as an exercise for the reader.
Then select the offset geometry and the geometry with the support:
and cut as a pocket from the bottom of the previous pocket to the stock:
which previews as:
@WillAdams I dont post much but you sir are a great contribution to this forum which for me is just a hobby. Learned a ton from your posts. THANK YOU!
Use this same technique for stacked text!
That’s a good point, it’s much the same technique.
A further point, the tittles in the i s need to be connected using a support as well — that was left out of the original image.
