WillAdams
(William Adams (Carbide 3D))
April 1, 2024, 12:58pm
11
The usual suggestion for learning CAD is to take some simple real world object, measure it, and draw it.
A classic example of that for Carbide Create would be a pair of wrenches:
I’ve searched, honestly, but I still can’t find out if the importing of images is fixed, or I’m just doing it wrong.
Essentially, I drew around a spanner (wrench) with the intention of scanning it, editing the image in Affinity Photo, and then importing it as a background, to draw a vector over it, or as a vector.
Except, it’s either the size of the Eiffel Tower:
[Screenshot 2020-11-09 at 17.28.40]
or the CN Tower in Toronto:
[Screenshot 2020-11-09 at 17.29.38]
Oh, and the stock size is …
Assuming of course one has seen the videos:
https://my.carbide3d.com/#Design_with_Carbide_Create
I’ve written a bit on the basics of Carbide Create which may help:
https://willadams.gitbook.io/design-into-3d/2d-drawing
The big thing is if you get stuck, let us know what you are having difficulty with and we’ll either find a relevant tutorial, or make a custom one — a few of the more notable ones:
As requested on support…
Given a file where one has text, and a support which one would want to be in the background:
[image]
it is pretty straight-forward to create two separate pieces of geometry which will cut out the text, and the text with support.
as requested on support…
Given a design which wants to be cut at different depths:
[image]
one would work up multiple pockets which will achieve the desired effect.
Given a design:
[image]
which one wants to fit in-between the two circles:
[image]
w/ 5mm or so border we would need to:
- select one element of the design
- delete everything else
- reduce the size so that the remaining parts fit
- edit the elements so that they match the circle geometry at their new size
- use the Circular array tool to duplicate as necessary
Carbide Create has gained a number of features which make this far simpler than it was in the past, so recreating a dial face such as:
[image]
Is now quite straight-forward, rather than using the rather rough auto-tracing.
