Re-working a design for a circular design
as requested on support…
Given a design:
which one wants to fit in-between the two circles:
w/ 5mm or so border we would need to:
​ - select one element of the design
​ - delete everything else
​ - reduce the size so that the remaining parts fit
​ - edit the elements so that they match the circle geometry at their new size
​ - use the Circular array tool to duplicate as necessary
First, ungroup:
deselect one element:
delete
Dupe and resize the outer circle to get the desired 5mm of spacing:
re-size to make things fit:
duplicate the circle and use Trim Vectors to make the outer design match:
and re-draw the design until it is symmetrical:
One concern is that the design must be rotated by a number of degrees which will evenly repeat around the circle — 6 degrees isn’t enough, 9 is too far, 7.5 degrees seems workable, but will require re-working the design a bit:
Duplicate elements as need and use Trim Vectors:
to get a set of vectors which can be used to re-create elements as needed.
Eventually one arrives at:
which one may use Circular Array to duplicate as needed:
