Since the full size thing isn’t easily doable on our machines (and I don’t want to be responsible for a child’s safety), we’ll do a model sized to a Barbie doll/GI Joe “action figure” child figure — this way it can fit on any machine, folks can scale up at need) — we’ll omit the decorative elements so as to avoid copyright issues.
First thing is researching the dimensions (not sure where my daughter’s Barbie dolls got to, and I don’t think she had any Skipper or smaller ones).
There are a number of sites which collect doll dimensions — for compleatness’ sake, here are the links found in researching this:
Estimating, it looks to be about 3.5 times longer than it is high, and 4 times longer than it is wide, so we start with a stock size of 8" wide, by 8" tall so as to have a bit of working room and begin by drawing in some geometry to roughly approximate a runner:
Make rectangles to define the base of the side and the side and other geometry as needed to define the desired shape, including rotation to get the back corner:
Then duplicate and rotate the part to determine the dimensions of the back and draw in a rectangle from the bottom edge to the top (it will be twice the desired size):
Change the width of the rectangle to match the anticipated width of the back (equal to the deck width) and draw in circles to define the arch at the top and the handhold cutout:
(and sourcing a dowel to serve as the handle at the front, and assembling — use butt joints for the back/sides, and if need be, drill a tiny hole to pin the cross members)
