“Turning” as in “on a lathe” ? What machine would you use ?
It’s not going to be easy or convenient to use Carbide Create for turning ops.
You could generate 2D profile toolpaths in an XY plane, but when using a lathe you will want to take multiple passes with a small radial stepover, and CC profile/pocketing toolpaths are not convenient to do that (it was obviously not designed with that capability in mind )
I have used a Shapeoko for basic turning, using Fusion360 turning toolpath capability and some extra hacking:
