How to import tool library database
I have a couple different bits from different companies and they offer files to import into Carbide Create. However, it appears that I can only manually import them one at a time.
Is there a method to upload this file into Carbide Create V8? It’s available in .csv and .rar.
Even these companies advertise that the file is ready for CC…
Thanks.
Sorry. I mean “manually enter” not manually import.
It is an unsupported option to manually edit the underlying .csv file. Go to Help | About | Open Data Directory, then open the Carbide Create directory and find a Carbide Create\tools directory — custom tools are stored in that in .csv files and may be backed up or saved or transferred to another computer, or edited using a text editor or spreadsheet (if one saves as CSV format).​​ See
and
as well as:
Problem is when you click HELP in CC v8, it takes you to a webpage.
I had found the other threads but I can’t get to the databases.
For documentation we have:
https://carbide3d.com/hub/courses/create/
and I wrote up:
https://willadams.gitbook.io/design-into-3d/2d-drawing
https://willadams.gitbook.io/design-into-3d/toolpaths
Contact those companies for help downloading said files?
Will - I always appreciate the quick support and help.
There is no way to open About in Help in CC8 to even start a process.
But alas, I was able to find it. It’s not located in HELP. Maybe on a windows product, but on my Mac it’s located under Carbide Create.
MK
