How to invert a DFX file
I have a cad file of a 2.5D relief and want to invert it so that the shape is cut into the wood rather than being proud of the wood. I’ve tried using -1 as the Z scaling factor but that didn’t work. Any ideas?
Cheers
Mike
Which tool are you using?
Usually the easiest thing to do is to add geometry — see the discussion at: Nvy logo svg file
Hi Will, I’m using Meshcam V6 but have Meshmixer, Inkscape,CC and Fusion 360 at my disposal if needed. I also have the file as a STL if that’s any help.
Cheers
Mike
Is there an option in one of those programs to Boolean subtract what you have?
Is the file a 3D model like an .STL or is it a 2D graphic such as an .SVG?
2D graphics can be manipulated with CC in the way that @WillAdams has shown. If it’s a 3D model you will need to modify it in a different way using either Meshmixer or Fusion 360. In either of those tools you could create a rectangular block that covers the entire relief and then do a boolean on it cut a reverse relief in the block. That would leave you a model you could use to create toolpaths for in MeshCAM or Fusion 360.
you an also convert the STL to a depthmap PNG (see other threads here) for use in CC
Thanks for all the help, I’ll try some of them this week and see how it goes.
Cheers
Mike
In the end I just remade the scrabble tiles in CC as I wanted to make some design changes anyway. I’ll keep the boolean subtract in mind as a neat trick.
Cheer
Mike
