I am new to Shapeoko and Carbide Create Pro, and I want to make a sphere with 10mm diameter and a 2 mm hold through the centre.
How to make a sphere with a hole through the middle in CC Pro
do you mean a whole sphere, or half of one?
A whole one needs 2 sided work (since you can’t really cut the bottom half in one go)
You can grab an stl of a sphere from https://commons.wikimedia.org/wiki/File:3d_model_of_Sphere.stl or https://www.thingiverse.com/thing:156207/files and follow the tutorial at Cutting STL models with Carbide Create Pro (nearly-2021 edition) (with 50% depth offset) to easily create the half sphere.
the hole through the middle you can then do with a traditional normal toolpath in addition
If you just need a 10mm sphere with a 2mm hole I use these
Thanks Kevin, I use them too, but I was hoping to let the Shapeoko to do all the hard work first then I will do the final polish after, haha… In fact I am actually interested to make some wooden billard balls, I would like to know how to use Carbide Create Pro can actually to create a perfect sphere, or I guest half doom, since I can only cut one side at a time.
Arjen, that great stuff, I will need to spend some time to play around with it, I am just new to this, hopefully, I will post up my success story in a few days.
