How to Plunge Cut
Hi gang, brand new to CNC with my Pro XL and did my first 16 inch circle cut last night.
2 big takeaways…
If you are going to use the material center as your “starting point” then make sure your starting point in carbide create is also centered (not lower left). That was a horrible noise.
when trying to cut a 16 inch circle make sure your material is not further back than the gantry will go. That was another horrible noise
So i tried to make holes in my plywood, 1/8 inch wide and 1/2 inch deep. I used the 1/8 inch endmill but no matter what i tried all the circles came out to be 1/4 inch wide. i tried everything and then read that you can’t plunge cut with a CNC. So my question is how can i make 1/8 inch holes?
thanks in advance, super excited to be part of this community
You can use a smaller bit which a 1/16 is impractical. You can try sizing to .126".
agreed, i’d be nervous that the 1/16 would snap pretty easily.
i adjusted the hole radius to .065 (from the original .0625) and it still cut 1/4 inch holes
i feel like im missing something silly
Post the file?
There’s an interaction between geometry size and Toolpaths type and Endmill diameter.
16_outside.c2d (987.8 KB)
16_flipped_all.c2d (1.4 MB)
Great, thanks for your help
so the OUTSIDE file is 3/4 inch plywood and the holes are for 1/8 inch dowels
the FLIPPED file is 1/2 inch MDF and the holes are for 1/8 inch dowels
i read somewhere that the dowel trick is helpful to keep your design aligned and the file is flipped so the dowel holes would be on the back of the artwork
hope that makes sense
thanks
So I think the problem is that you’ve chosen a “Contour” for the type of toolpath for the circles…and put the No Offset option on. What that does is center your 1/8" bit on a 1/8" circle, meaning half of that bit is outside of the circle…so you’re effectively adding 1/8" to your 1/8" circle = 1/4" circle.
You can either use a smaller bit and POCKET the circle, or use a 1/8" bit and DRILL the circle. That’s the toolpath choice that will work.
EDIT: You could also use a 1/16" bit and CONTOUR the circles with an INSIDE option. Which would effectively do the same thing as a pocket, but maybe more efficiently. But I think the DRILL toolpath with a 1/8" bit is the best choice.
drill path for the win!! i had only known to use CONTOUR and honestly didnt understand the rest of the tabs. you can see after accepting my fate of having 1/4 inch holes i just now cut the 3 successful holes that fit the 1/8 in dowel perfectly.
Gary, thanks so much for your help, i really appreciate it :smiley:
That’s what they don’t pay me for! :slight_smile:
ok, so i think i have everything set right. i have the circle cut as a contour with 1/4 inch endmill and now have the plungedrills set to 1/8 X .375
i just clicked on show simulation and i see this. anything to be alarmed about or just run it?
Is the X, Y zero in the same building as the machine?
hah, yes it should be. everything was fine until i added the drilling toolpath then the simulation went wonky. i drew everything in the design tab and then added all the holes to the drill path under toolpaths.
16_outside_V2.c2d (986.8 KB)
I thought it looked off.
Unfortunately I’m not a Carbide Create user so I’ll have to leave it to those who know to say how to fix it.
it’s like the drill path is set to start waaaaaaay off screen, not sure how to adjust that.
It looks like it’s starting on the workpiece but picking up a drill point way off to the right, is there some feature out there selected somehow?
yup, found some little guy stranded waaaay off the screen. how he got there is anyone’s guess. That’s why i shouldnt select all when creating a new toolpath.
thanks again to everyone for their help
Hey,
You checked the toolpath before running it, that was the sensible bit, I never run a toolpath without viewing it or watching the simulation to see what clamps it’s going to plow through first :wink:
Do you model your work holding? I can see value in that but if one often gets creative with work holding, I can imagine it might get tedious.
I don’t, But I try to keep my retract height above the clamps if I can.
You’re right, it’s a lot of effort for one-off jobs.
I model fixtures where I’m using them so that I can see locating dowels, bolts etc. and try not to send the cutter through them. I also modelled my 100mm jaw vice and can import that into the model when I do CAM to show how the workpiece is held and where the heavy parts of the vice are.
For ad-hoc clamping onto the spoilboard I watch the simulation and then place clamps in areas which seem to be clear, or I tweak retract heights on the paths which rapid through areas I want to clamp.
so by model your workholding do you mean manufacture them ourselves?
