Is it possible to use more tools for the same part? For example, I need to make a pocket around some text. In the beginning, I use a bigger tool to remove the material as quickly as possible.
Certainly, it’s impossible to make fine details with this tool. So I need to use a smaller tool, but I don’t want to cut the whole pocket again, only finish the details that were impossible to make by the previous tool. If I try to make another toolpath, it will still clear the whole pocket.
I don’t think I am fully getting the idea. Would this be done as if it was two different jobs? The rough pass would be first with the original selections. Then the next one would be with the offsets to use the smaller bit. It seems like kind of a pain, but it clearly would save a lot of time.
