Hoping someone can give me guidance on how to surface my wasteboard safely. In return, I’ll record a tutorial so we can share it with the other noobs like me as they join the forums
Thanks!
Thanks!
Rob has mentioned elsewhere, but the easy thing to do is make a MeshCAM job that is the exact size of the wasteboard, Program Zero at a top corner, do a parallel-only finishing with 75% or so stepover, “machine geometry only”, 0 margin, uncheck “Don’t machine top of stock”. When you set down the flat-end cutter on the wasteboard, call it Z .010" or .25mm or how much you want to face the board down. MeshCAM will make a single lawn-mowing pass back and forth across the top of the wasteboard. If you haven’t skimmed enough off, touch off the cutter again and call it Z .010" or whatever again and repeat.
Thanks Randy. Just to confirm, when I’m setting the zero in carbide motion, I zero x and y but I set the bit on the top of the waste board and set it to .010 or whatever I choose? I’m assuming that the cutting pass will then move the cutter down .010 to get it to true zero?
Exactly, Darren. (The BBS software won’t allow posts of < 20 characters so this is fillin)
Awesome - thanks! Excited to give this a try tonight. And I’ll cite you in the tutorial video
Thanks, Darren. But cite Rob please. I would have done the lawn-mowing from my 2D CAD macro unless he hadn’t sparked the idea…
I’ll say “Robandy” helped
haha
