I have pdf stencils I want to import and cut out
I have pdf stencils ,I want to in port and cut out machine parts 4 my cnc
i have built a cnc my parts r not perfect but if i in port trace and cut them back out
For one example of doing this see:
Basically one opens the .pdf in Inkscape (or some other drawing tool such as Serif’s Affinity Designer), if desired, edits there, re-saves as an SVG, then imports the SVG into Carbide Create.
For notes on fixing clipart and other problematic files see:
If you’ll provide us with an example file (or send it in to support@carbide3d.com) we can look into this with you.
