Incorporate STL into project
Hello all,
I am trying to incorporate an STL into a larger project and am failing to understand how this works. My hope here is that when working with an STL, you’re not locked into that single STL being the entire project. Or is that how this works?
For example, I just want to create asign that is 180mm W, 19mm H, 570mm L
On the left side of the sign, my goal is to create a 6mm pocket circle that my STL can be placed in and then use addition of 4mm starting fromthe floor of that 6mm circle.
Then still be able to carve the letters for my sign to the right of that.
In theory, this seems like it should be a very basic type of activity in this world, but i am clearly missing something.
I’ve watched thevideo from carbide and several others online that simply show how to bring in the STL and carve it as the entire project, which I can do.
My throught here is…
  • Create the initial project on design with everything except for the STL
  • Create an outline that matches the stock size
  • Create an outline, sized correctly for the STL where it needs to be
  • Go to model and select the vector that outlines the stock
  • Add a shape, Flat, and set the thickness to 19mm
  • Select the vector forthe circle where the STL will go and add shape flat and Subtrack 6mm
  • With that vector selected, import the STLand set the necessary properties
Also finding that once you set something on the model side of the house, it’s done. No ability to change hardly anything if corrections need to be made.
What am I missing here? Really appreciate any insight, directions, videos, other posts I’ve missed.
Thanks, all!
Bob
That’s the way it is in v7, but wait, there’s hope!
Please try the v8 beta:
which specifically adds this facility to edit as an option.
Yes, you can definitely merge 2D & 3D, and I would highly recommend it. There is no need to 3D carve the 2D portions of your project. It’s just a waste of time.
The vector you choose when creating a 3D toolpath is a boundary. It will cut the 3D model within the boundary.
You don’t even have to model the whole project, just the area for the 3D cut.
Here’s an example with the model only inside the circle
