Inlay gaps - any ideas?
Geometry matches up, so files ought to be good.
On concern is you’re cutting a slot over 3/4" inch deep w/ a #102:
It would be better to use a more rigid tool and to add geometry and cut as a pocket down to tab depth or the penultimate pass:
A further improvement would be to leave a roughing clearance and make the last a finishing pass.
And if you haven’t, yes, you should calibrate:
That said, why not do a V inlay?
