Would a HDZ user comment on how they keep dust and metal shavings out of the ball-screw and linear bearings on the rails? Perhaps it’s by virtue of having dust collection; if so, does that mean that dust collection is required at all times? thanks in advance.
When cutting anything else than metal, yes, dust collection.
When cutting metal: a chipguard mounted under the router
Like Julien says, some sort of deflector or dust hood comes first.
However, the linear rails and ballnut both have seals & wipers on the ends which assist in clearing surface dust and chips. How long these can keep the ballscrew and rails clean and working is a different question however.
Sawdust is pretty easy to push out of the way, larger machines and those cutting metals and other abrasive materials generally use a set of bellows or other shields to keep the crud off the linear rails.
Thanks for the quick replies.
There might even be 2 M5 x 6mm screw holes on the base to build your own deflector…
Ha! where were you when I designed a montrosity of a custom 3D-printed dust shoe frame just to circumvent the absence of a good anchor point on the bottom of my HDZ?
Very useful detail ! HDZ 4.0 owners will put them to good use I’m sure
Deflectors.zip (11.1 KB)
For anyone who wants to make one
You mention the inclusion of M5 Screws, are these on the bottom of the plate that holds the bearing for the ball screw? Trying to picture in my head how I could use this for a dust boot.
Screw holes.
These are not load bearing and I don’t recommend fitting anything to them but a small, light deflector.
Cue a demonstration of the difference between “recommended” and “what people really do with their Shapeoko” ![]()
So I’m guessing that if they’re in the lower bearing plate anything too large attached is likely to deflect the bearing plate and cause an unhappy ball screw and unhappy owner then?
The HDZ 4.0 looks like a well engineered piece of kit, well done to all involved.
Just a thought (from someone still using the stock, belt driven, z). What happens when the operator of the HDZ is using the Bit Zero and forgets to fit the alligator clip? Obviously with the belt z, the belt slips. What does the ball screw do? I assume that a small diameter bit will snap, but would it try to drive a 1/4" bit into the Bit Zero, or damage the ball screw?
Been there, done that : indeed a small bit will probably break, and when doing that mistake with a 1/4" endmill, beyond the fact that it is really unpleasant during the few seconds it takes to hit the emergency switch, nothing really bad happens: the bitzero and HDZ are sturdy, so the stepper motor gives up first and “just” looses Z steps and clicks. Very unpleasant feeling. It just left my probe with a tiny scratch (the tip of my #201 did not look chipped, but of course it’s not a good thing to do to an endmill). The ballscrew just laughed.
Pretty much sums it up. Usually it damages the next weekest part, you might snap a V wheel or the motor will skip.
The v wheels give in first
Ha, feels like this is where we all admit our mistakes. When I did it, it scratched the top of my probe a little bit during the time it took me to dive towards the switch. It started to slide the probe off the part, causing the scratch.
Yeah,
On the XXL you get to watch the bed deflect by a good 1cm (1/2 inch) if you’re in the middle whilst you remember the big red “STOP!!” switch.
Of course, now that I’ve reinforced the bed I will see one of the above results next time I make that mistake.
The HDZ really is a well made bit of kit.
I can attest that the XL baseboard bends the knee to the HDZ in such a scenario.
So, the shop page,is still saying HDZ 3.3 and pointing to the 3.3 installation page. I’m not quite sure what I’m gonna get if I order something…
All orders are going to be filled with the HDZ 4.0 I think the installation instructions are there, as I’m not sure they’ve updated them yet.
