Hello, I just got my machine back and running thanks to some help from our awesome forum. I’m having an issue where I was taught by the forum too use a offset path and pocket command before you cut all the way through a three-quarter inch piece of wood around the outside of something. Problem is the pocket command is cutting all of one side of the pocket to full depth, and then the other side of the pocket, rendering the entire point of this useless as far as I can tell? Can anyone tell me if I have something programmed wrong?
Post your file?
The pocket should only go down to tab height, see:
Similar issue discussed here: Pocket toolpath still trying to slot cut - #4 by CullenS
