Does anyone have a post processor working with the new Vectric 10.5 software. I keep getting error messages when I try to get the laser settings to work with a post processor and the gcode won’t save. Not sure if I have a messed up install or there is some kind of conflict.
If you have it working could you put up a screen shot of your laser tool settings in Vectric and where you got your post processor.
Using the new Laser Tool and attempting to create a toolpath I get
Error Occurred while outputting toolpath
Check the post processor you are using is compatible with the toolpath you are trying to output
If you want you could check out my post about the Feed Rate issue here
Edit - Sorry I somehow confused processors. Using your post I do not get the error but it still has the feed rate error I outlined on my post at the vectric forums.
Ok, then change “error” to “feed rate”. Same question.
The reason is that Vectric has stated that they fixed the feed rate situation, and included it in 10.505. That doesn’t mean it got magically installed, though. They have exceptions about whether a post gets installed.
The problem is that at line 9 CNCjs produces an error because there is no defined feed rate at this point. And since line 8 has raised the Z to 5.08 it then makes the subsequent cut too high. If I move the feed rate from line 11 (F500) to line 9 it works fine.
Looks like the same issue with the post you just sent.
G1Z0.0000 (line=9)
error:22 (Undefined feed rate)
Of course this only happens if this is the first file you run, Apparently the feed rate is kept in memory, so if you ran any other gcode beforehand this file will run fine
Use the GRBL post processor. I have been able to get it to work fine. I am going to try Neil’s this evening. Neil would you send me the latest version that you want me to try.
