Just finished assembly of my Shapeoko Pro XXL and started the initialization z motor (spindle) went straight down to the board and started to try and drag to the left. Please help.
WillAdams
(William Adams (Carbide 3D))
June 26, 2022, 2:42pm
2
Did you send the correct machine configuration?
Carbide Motion 517 uses a new system for setting Travel Dimensions which is potentially confusing:
[image]
Pressing the Load Defaults button takes one to a window which allows one to select first machine size:
[image]
and then Z-axis type:
[image]
after which selection the Travel Dimensions for the selections made are entered into the dialog and will be preserved if one clicks “Ok” (and of course that change discarded if one selects “Cancel”).
In addition there is a “Send Configuration…
Are any homing switches stuck on?
Let us know at support@carbide3d.com
system
(system)
Closed
July 26, 2022, 2:23pm
3
