Laptop requirements
I have the Shapoeko Pro 2 x 4. I have been using a table and have had some issues with it.
Would this laptop work with my unit?
Dell Latitude 3310 13.3” Laptop
Intel Celeron 4205u @ 1.80GHz processor
4GB Ram
64GB SSD Solid State Drive
Windows 11 Pro (64 bit)
Intel UHD 610 Graphics
1366x768 Screen Resolution
USB 3.0 Ports
Webcam
HDMI Port
Wifi
Factory reset so it’s like new!
Comes with good charger and battery
30 day replacement or repair warranty
System requirements are on the downloads page:
The one notable issue here is:
Screen Display: 1280 x 1024
so that system would fall short vertically — it might work for current and earlier versions of CM, but Carbide Create will either have you scrolling a lot, or have UI issues.
The display resolution height spec for Carbide Motion really doesn’t make much sense.
Pretty much all display panels are 16:9 or 16:10 resolutions now unless you go ultrawide. I haven’t seen a 4:3 display in forever. And the spec aspect ratio is for something in-between - 5:4???
I maybe recall using that spec on an old CRT monitor 20+ years ago.
Would love to know how CM got tagged with this.
But honestly, I don’t see how Carbide Motion could possibly not be designed for 16:9 displays with a minimum width of 1280px - which means a height of 720px.
Your laptop should be fine both in terms of compute capacity & display resolution.
I run Carbide Motion on a RPi5 with a 10" 1280x720px touchscreen & it’s perfectly fine.
We did run a poll:
and the answers were overwhelmingly skewed to larger (presumably greater pixel resolution) displays.
the Latitude 3310 can have an external HDMI monitor attached. is HDMI 1.4a port, should play full HD 1920x1080.
