Any luck figuring this out?
Nope! Rack and pinion is on the radar next.
Do you have a link for the belts and pully you purchased.
Here’s the belt source (Qty: 3 needed): Gates 1536-3MGT-15 PowerGrip GT3 Synchronous Belt 9400-5512
Pulleys (Qty: 3 needed): https://us.misumi-ec.com/vona2/detail/110303274020/?HissuCode=GPB24MR3150-B-PUC
Currently waiting on a quote from KHK gears for the rack and pinion.
That will probably be tested on a scrap piece of extrusion, linear rail, and Nema23 motor mockup and testing it with an indicator before committing to do it on the Shapeoko.
KHK got back today and said a 1/4" bore in the gear requires wire EDM for some reason
Interesting and odd. 1/4" isn’t that small for a lathe boring bar and a reamer?
Wonder if it would just be better to get a Nema23 motor with 8mm shaft since they seem to be readily available?
KHK is wanting $255 to get three of their stock tapered pinions modified with a shortened hub and two M4 set screws. Only two week lead time.
Doesn’t seem bad at all This would be for an 8mm shaft Nema23 motor.
