Someone asked if I had ever used my JTech laser on anodized aluminium, and I hadn’t, so of course I HAD to try.
I have the 2.8W model, so not lots of power under the hood, but for engraving stuff it has proved to work well. Anyway, I bought a bunch of black anodized aluminium cards (100mmx50mm) on Amazon, and got them tonight.
I had NO idea what laser settings to start from, from I just rolled a dice, and chose to try 80% power, 2000mm/min, 0.1mm “stepover”, 400mm accels.
Not bad for a random run. The logo can use some improvement though to reach a perfectly uniform surface though.
I will update this thread as I test other parameters, but if you have examples of your own of laser etching anodized aluminium, feel free to post them there here and we can share tips!
Oh, that looks pretty great for first try (and also thanks for doing this!). The makerspace near me has a 100W Boss laser (that is now constantly having user error issues I think). I was able to do these on it:
@Radiation: thanks for sharing those settings. I googled a bit and apparently there are two “schools” for etching anodized aluminium with a laser:
the big guns (100W laser like you mentioned) will vaporize the anodized layer completely, which grants the cool look of “fresh aluminium” showing where the laser went.
the waterguns like my 2.8W laser can still be used but it seems like what they do is kill the dye in the anodized layer, without actually removing that layer. Hence the grey look I guess, but taking multiple passes or going slower may help there, we’ll see.
@RoughDraft40: I never tried engraving photo images, I guess that could be part of my second try. I also saw that Vectric now provides a laser module for VCarve that does photo lasering. I’m not quite at the point where I want to buy it (it would be mostly redundant with LightBurn), but there is a trial version, I might take a look.
