Can the layers please be made into a regular part of the interface? Right now the model window means a ton of opening and closing that make layers more trouble to use than they should be. If they had a permanent (non modal) space under the Import block, they would get a lot more use. Make it collapsible if needed, but there is currently plenty of extra space there.
I think a shortcut key would be great. ie Control + L.
I agree, it would be much easier/nicer to use if it could be always available.
As Will has noted that the shortcut key is L. I move in and out of layers pretty fast by just pressing the L button and doing what I want for a particular layer and then closing the box again.
That makes sense why Control +L isn’t working. lol.
Glad it works for you. Sure, click L and there it is, right in the middle of your work space. So then you move it to the side to access your work. Repeat multiple times and, for me, it’s too much hassle to be functional. Why have to close the dialog to access your work? Carbide Create has made great strides forward in the past couple years, this element needs work.
