I’m cutting out letters to glue onto a sign and also using the pocket tool path at .03 to plow out the letters for alignment, the problem is the actual letters aren’t quite the same shape as the pockets. Any thoughts? I’m using a 1/8” end mill. Thanks
A round tool can cut square outside corners, but necessarily leaves a radius on inside corners.
You will want to either use a font which is designed so as to not have these problems, or you will need to:
Inset by the radius of the tool used:
Apply
Then offset to the outside by twice that amount:
Apply
and lastly, inside by the original amount:
Apply
which then yields a shape which may be cut as expected:
Thanks guys that’s very helpful one more question, if I use the curve tool or a font with curves do I use an offset when cutting the letters or cut on the line in order for them to line up with the pocket?
Depends on your material and tool.
One the line might work, or you may need an offset — my recommendation is to start with a single letter as a test — cut it out, then cut the pocket, then do a test fit, then adjust and re-cut the pocket.
Note if you’re using a belt-drive machine you should calibrate for belt-stretch:
