All LEDs light up on my switches and are recognized in the settings. Any help would be greatly appreciated. After I disconnect the motor I can raise the Z axis manually. Then it will start but once it goes all the way down it fails, if I raise it all the way up and start it fails and says it can not find the switch. At a loss.
If you have sent the configuration and you are still failing homing I wrote a doc to help you trouble shoot the proximity switches. The assembly instructions have you mount the switches they may not be triggering. Let me know if the doc helps.
