i’m looking at cutting .1" aluminum plate. i have stock xxl, mikita router, carbide end mills, no mist system.
i understand there’s a fine line between melting the aluminum and actually cutting it. i’m wondering, based on everyone’s experiences, if the suggested feeds and speeds in carbide create are a good starting point and if i should use a flat end mill or a ball mill? 1/4"? 1/8"? should i use cutting fluid and water in a spray bottle? or just one or the other, or anything at all?
would appreciate any info y’all have or if you need more info from me. i don’t really have extra stock, so i’m hoping to get this right on the first go around, even if it means taking more shallow passes.
i’m cutting down a 12x24 piece into 3x4 tags, was just going to do square cuts, but if this proves to be fairly simple i’d like to scallop or chamfer the corners.
was planning on painters tape on the waste board and the aluminum, then two sided tape or glue. trying to avoid having to clean a bunch of sticky residue off the piece.
i’ll see if i can approval to buy new bits- the single flute really makes that much of a difference in keeping the heat down? i haven’t used one before.
3000 and 5000 series aluminum are pretty gummy and the sweet spot between gumming up and cutting good is really narrow. I’ve cut 5000 series, but not 3000 series
1 - I would use a flat 1/8" single flute upcut. The 1/4" is more rigid, but for a given RPM, it is traveling way faster, so you would have to kick up your feed rate a lot to get the proper chip load. The single flute helps chips clear out and reduces the chip load.
2 - I would reduce the depth of pass to more like 0.020". There is less material to clog the flutes of the endmill and less friction on the sides imparting heat. This also allows you to increase the chipload by increasing feedrate. If I have a choice in aluminum I increase the feedrate and reduce the depth of cut and/or stepover.
3 - I would use a ramping entry rather than a plunge.
4 - I would double that plunge rate to 20, and the feed to more like 50 or 75. The RPM should be good.
5 - I like to do a roughing then a finishing pass. That gets the wall finish better and for the finishing pass, gives the chips a place to help them eject.
6 - I would get some air blast on the cut as well. Help it all cool off a little as well as get the chip away.
