Machine stops carving
I just got my Shapeoko 5 pro and getting used to Carbide motion. I programmed a job and twice, the Shapeoko just stops engraving with Spindle running. What causes this?
EMI or the USB cable vibrating loose are the usual suspects.
If you check in with support we will have you run an air job and work through a 10-step plan.
See:
https://carbide3d.com/blog/dust-collection-disconnects/
for reference.
I’m carving acrylic with no dust collection. So thats not an issue. I have air assist to clear the work area. Again yesterday, I had a 20 mins project and had to restart at the begining and at the end ,I had one number left to do and it stopped. So having to re-run 20 min projects three times is not time efficient.
Let the folks at support know what you have tried and the specifics of your setup and we will look into it with you.
