Machining a ramp in plan view
i was trying to figure out how to cut a sloped surface with e ball end mill.
i can not find any way to do this.
it would be similar to the carve pyramid but i want only one plane.
i.e. cut from surface top to 1/8" deep 1" to the right or left.
kind of like machining a door stop in plan.
You have to make more than two times the area one wants and then adjust accordingly, see:
Or, model in a traditional 3D tool, export as an STL, then import the STL and cut that.
